sahil10
Honda CITY GX missing problem..
I have a Honda City Gx model. The problem in my car is that sometimes the car gives jerks when being driven... When the accelerator is pressed the car moves on normally but sometimes when the accelerator is pressed the car gives a jerk and then moves forward.
What could be the problem in my car??
As service is done a mere 1500kms before, uncleaned injectors does not seem to be the cause.
I too, completely agree with Naren, that adulterated fuel could be a high possibility causing mis-fire of engine.
PS : You could also check out with the Service-center people to check-out whether they have cleaned the injectors or not. This will help in narrowing-down with the diagnosis.
