Gurkha
my 4WDs.
Gurkha specs..........
OM616 turbo engine, IFS, selectable at any speed 4WD, floating rear suspension with two piece axle, divorced PUCH transfer case, ZF 5 speed, ZF power steering pump, BEHR radiator and oil cooler, diff locks on front and rear axles. Tubular chassis, indpenedent dual wishbone torsion bar front suspension. 240mm ground clearance on 16" high profile tires. Corrugated pressed steel body with electro phoretic paint process.
Its out and out a Tempo Trax Gurkha, with the Merc pointed star and alloys/ wider tyres and mechanical modifications as Gurkha has recorded above.The OM 616 ( licence from Merc Benz) powers the Tempo Trax variants, the Tempo Traveller and Matadors.
