Aakash77
Civic Steering Problem
Hi. I have a CIVIC 2007 MT. I am facing problem with steering of my civic since
two months when i got steering bush changed. The steering wheel doesn't
come back while taking turn/u-turn or maneuvering in city driving. It
stuck to the position in which i turn the wheel. The problem was not
there before changing the part. I got the part changed from the
authorized service center in delhi. Automax Honda. After several visit
and check-ups by the adviser and technicians the problem still persist.
They have checked every parameter and system related to steering but the
problem is still there. Please advise.
The Civic steering is not over servoed like many. Obviously you have a too stiff bush - could be either lack of lubrication, or too tight a bush fit. The dealership should be able to fix it easily. Obviously the problem is in city driving only so the stiffness is quite marginal. Even a silicone oil spray may be all that is needed. Once it beds in the problem will go away.
Good evening. Can you suggest any good service center in delhi, with whom i can  discuss my problem. i am thinking to visit Autopsyche or Performance auto in Noida.
Thread moved,
BornFree2011-01-15 16:04:12
