tejasmehta990 4 Report post Posted December 29, 2010 When there is a growing popularity for compact SUVs in India and number of manufacturers are introducing innovative compact SUVs (Mini Xylo , Premier Rio) can we expect Maruti to introduce "Suzuki Jimny" as "New Gypsy" ? This vehicle seems appropriate for city driving (compact dimensions) and offroad driving (rugged , 4 x 4, ground clearance, etc...). This vehicle can be a rightly positioned as an affordable SUV just like EECO. Quote Share this post Link to post Share on other sites
creativebala 178 Report post Posted December 29, 2010 Will be a super hit if launched with MJD from Day1. IMHO, this SUV doesn't have the brawny looks, an SUV should possess. Quote Share this post Link to post Share on other sites
tejasmehta990 4 Report post Posted December 29, 2010 The best thing about this vehicle is that most of the features as required by the Indian buyers. It is also equipped with 1.5 diesel so no need for Maruti to change even a single spec. Only drawback is that it is 4 seater. But this vehcile can become a perfec lifestyle and personal vehicle for all purposes. Tech Specs from Jimny's official website http://www.globalsuzuki.com/automobile/lineup/jimny/spec/index.html Engine Petrol Diesel 1.3L 1.3L VVT 1.5L DDiS Drive system Part-time 4WD Transmission 5MT 4AT 5MT 4AT 5MT Steering LHD/RHD LHD Number of doors 3 DIMENSIONS Overall length Front bumper to rear bamper mm 3,570 Front bumper to spare type mm 3,645 Front bumper to spare wheel cover mm 3,665 Overall width mm 1,600 Overall height Without roof rails mm 1,670 With roof rails mm 1,705 Wheelbase mm 2,250 Tread Front mm 1,355 Rear mm 1,365 Minimum turning radius m 4.9 Minimum ground clearance mm 190 Approach angle deg. 37 Ramp breakover angle deg. 31 Departure angle deg. 46 CAPACITIES Seating capacity persons 4 Luggage capacity Max volume litres 816 Rear seatback folded (VDA method) litres 324 Rear seatback raised (VDA method) litres 113 Fuel tank capacity litres 40 ENGINE Type M13A K9K Number of cylinders 4 4 Number of valves 16 8 Pisiton displacement cm3 1,328 1,461 Bore x stroke mm 78.0 x 69.5 76.0 x 80.5 Compression raito 9.5 18 Maximum output kW/rpm 60/5,500 62.5/6,000 63/3,750 Maximum torque N・m/rpm 110/4,500 110/4,100 200/1,750 Fuel distribution Multipoint injection Direct injection (common rail) TRANSMISSION Type 5MT 4AT 5MT 4AT 5MT Gear raito 1st 4.425 2.875 4.425 2.875 4.246 2nd 2.304 1.568 2.304 1.568 2.357 3rd 1.674 1.000 1.674 1.000 1.695 4th 1.190 0.696 1.190 0.696 1.242 5th 1.000 - 1.000 - 1.000 Reverse 5.151 2.300 5.151 2.300 4.436 Final gear ratio 4.300 4.090 4.300 4.090 3.416 Transfer gear ratio High 1.000 1.320 1.000 1.320 1.000 Low 2.002 2.643 2.002 2.643 2.002 CHASSIS Steering Recirculating ball Brakes Front Disc Ventilated disc Rear Drum, leading and trailing Suspension Front 3-link rigid axle with coil spring Rear 3-link rigid axle with coil spring Tyres 205/70R15 WEIGHTS Kerb weight kg 1,060 1,075 1,060 1,075 1,155 Gross vehicle weight kg 1,420 1,500 Quote Share this post Link to post Share on other sites
dineshzma116 0 Report post Posted December 29, 2010 Will be interesting if it is launched as a two seater front cabin, and the rest of the people at the back like an ordinary truck. I dont like the shape of its backside cabin and named it as a SUV. -dinesh (always the racer wins atlast) dineshzma1162010-12-29 09:26:38 Quote Share this post Link to post Share on other sites
nikvint 1 Report post Posted December 29, 2010 http://epaper.livemint.com/ArticleImage.aspx?article=28_12_2010_008_002&kword=maruti%20to%20launch&mode=1 The above link shows that, maruti is planning to launch the Jimmy in 1-2 years. Once it's new assembly line in manesar plant will be ready by march-12, they will launch the jimmy. But we have to see, the pricing, options of engines and offerings from competitors.. All the best. Quote Share this post Link to post Share on other sites
Durango Dude 2 Report post Posted December 29, 2010 Maruti's platter is already full and overflowing. Of the top 10, 7 are from Maruti. I have a feeling Maruti hasn't exactly judged this demand well and has been caught on the wrong foot, leading to huge wait lists of it's Swift and Dzire. It's ironical, that it can't afford another "blockbuster" at the moment to send its production plans into a tizzy. If brought here, sure the Jimny would be a very refined lifestyle vehicle would succeed. Maruti can bring it on with the petrol and diesel avatar's. Quote Share this post Link to post Share on other sites
shanthanreddyp 0 Report post Posted December 29, 2010 For me the interiors looks like the Wagon R.4 door will be a good option as Maruti has a Fiat derived engine to plonk in and it can be done very fast. But if Maruti want to increase the production of all it vehicles and also launch new ones then it better start building another three factories at once because it is already stuck with capacity constrains and will only take thinks from worse to worst . Thread title edited. BornFree2010-12-29 17:19:11 Quote Share this post Link to post Share on other sites
rahul1810 0 Report post Posted December 29, 2010 It's ironical' date=' that it can't afford another "blockbuster" at the moment to send its production plans into a tizzy. [/quote'] I am pretty sure Maruti is not complaining! On a serious note, I would first like to see how much Thar actually sells. Off roading is not something major in India. For Jimny MS might even get some support from Defense ministry. Maruti has another capable 4X4 in SX4 hatchback though and it might be more practical to bring it along with 2WD version. Quote Share this post Link to post Share on other sites
CYRUS43 0 Report post Posted December 29, 2010 This car is one of the Girliest, most awful looking cars on the road, and no self respecting man would ever drive one. Quote Share this post Link to post Share on other sites
sarabjeet 3 Report post Posted December 29, 2010 well there would be difficulty for Jimmy to make it though , because it uses the multi-jet engine which is co developed by GM , so US would raise objection. SX4 would have issues in LEH Ladak on 4X4 roads Quote Share this post Link to post Share on other sites
dr_nishu 198 Report post Posted December 29, 2010 Maruti's platter is already full and overflowing. Of the top 10' date=' 7 are from Maruti. I have a feeling Maruti hasn't exactly judged this demand well and has been caught on the wrong foot, leading to huge wait lists of it's Swift and Dzire. [/quote'] Well said Sir.. & Maruti Suzuki have already reacted to this trouble, as confirmed by the news below; Maruti to reorient production of Swift, DZiRE Gurgaon, December 22The country Quote Share this post Link to post Share on other sites
dcarlover 0 Report post Posted December 29, 2010 well jimny is nt new...it was also sold in india earlier..i think??? Quote Share this post Link to post Share on other sites
Durango Dude 2 Report post Posted December 30, 2010 This car is one of the Girliest' date=' most awful looking cars on the road, and no self respecting man would ever drive one. [/quote']So what, Maruti may write another slogan for that: "Women are back". haha. Quote Share this post Link to post Share on other sites
BonFre 0 Report post Posted December 30, 2010 This car is one of the Girliest' date=' most awful looking cars on the road, and no self respecting man would ever drive one. [/quote'] Beauty is only skin deep, scratch beneath the surface & its an accomplished vehicle, built to fulfill its purpose. Agreed it does not carry that pseudo-macho image but who needs it! Its for real men & not those who like to send a msg. through their rides! BornFree2010-12-30 03:22:40 Quote Share this post Link to post Share on other sites
tejasmehta990 4 Report post Posted December 30, 2010 It is observed that a car with practical features, good A.S.S., VFM, right price are successful such as XYLO, EECO, Bolero, Indica, Maruti 800, Maruti Omni, than the cars with good looks. Considering overall outlook of Jimny the price should not be more than 6L . The force behind Jimny is the name associated with it i.e "Maruti-Suzuki" which will make it most successful compact SUV. What I liked about Jimny is - Compact dimensions - Offroad capabilities - Basic comforts features, A/C, Power steering etc... - 4 x 4 - Seating capacity for 4 + sufficient luggage space. - High ground clearance. - Maruti Suzuki Badge - Appropriate personal vehicle for city driving, weekend drives as well as for some not very serious offroad driving. - Diesel option - I can venture my dream drive from Kanyakumari to Himalaya in this vehicle very comfortably. Quote Share this post Link to post Share on other sites
esteem 0 Report post Posted December 30, 2010 The vehicle has a 40 year old history, I am sure Brand Jimmy must be doing something right to tickle the wishbones of its prospective buyers for so long.. Quote Share this post Link to post Share on other sites
tejasmehta990 4 Report post Posted December 31, 2010 Premier Rio is quite similar product as Jimny but because Jimny is offered from Maruti it will be able to attract consumers. Quote Share this post Link to post Share on other sites
GuruGautham 2 Report post Posted January 17, 2011 I have heard that the Jimny is available with a 80bhp engine in the Emirates which is absolutely inadequate for an SUV but I have also heard that it is as capable as a Freelander or Jeep off road so ideal vehicle to replace Gypsy Wonder whether the army will replace the Gypsy's with Jimny's. And those alloys look butch Quote Share this post Link to post Share on other sites
arun1987c 0 Report post Posted January 17, 2011 May be Maruti can think about relaunching the Gypsy with latest features and engine.... When Mahindra can do it with Thar, why no Maruti Come on Maruti guys, time to wake up... Quote Share this post Link to post Share on other sites
