anirudh
TVS Wego vs Honda Activa
anirudh
i do know but i see lot of wego on the roads these days..and it looks wego got bigger wheels...just check it up...
according to me suzuki access is better than honda activa...just try and see.i drove it..its simply superb
go for wego. i am using it. its road manners are very good and performance is also to the mark.
and to top it all it comes from TVS and you can be assured of the quality.
milage is around 40 to 45 km/lt in city drive.
lighting is good in its class
i m confused' date=' read somewhere jive and wego shares the same engine.  [/quote']
I've also Read the same somewhers, don't remember the source though.
Probably their engine specifications are same or some other parts may be shared but;
-Their Engine layout design is different, as Jive's Piston movement is Vertical, while that of Wego is Horizontal.
-Transmission of both differs, as Jive uses 4-Speed Manual while Wego uses CVT-Automatic Gearbox.
Suzuki Access is much better than honda activa and wego
Also you get the vehicle immediately.
Becoz of non availability of activa immediately, most of the people are going for Access and it got more power than activa.
