AUTOYAAR
Swift vxi nov 2007 model .
74,000 Kms is bit on a higher side, if you want to keep it for 1 or 2 years then its ok. However, if you want to keep it longer then give a second thought. Do check the condition and history carefully before buying. Infact, you can also get it checked from a authorised Maruti Dealer.
A good second hand Swift VXi/ZXi with around 25 K on the odo should be reasonable. Even then its better to get it checked by a trusted mechanic. Maruti True value is more reliable for second hand buys though they charge a little extra. In addition the cars have a six month warranty.
