Mr. Spock
Intermittent Burning smell from A/C
Whenever I am driving my swift and A/C kept in rec.mode and after a gear change there is smell of  burning plastic which lasts few seconds.This does not happen when fresh air is selected.Is it due to clutch or transperant mats used in the car.
@mods - if similar thread exist please merge this thread with it.
It could be, but first you should check with Maruti-Suzuki. I remember 3 years ago I have sat in a new brand Indica.
        which is also having same problem with A.C but owner never mind it instead of it he use to put deo in air vents when burning smell come which ultimately relive us from bad smell and burn our eye cause that deo finally come into back seat passengers eye.
