fitsandy 0 Report post Posted March 28, 2011 Hi Friends ! I just bought a 1999 Merc E 240 V6 Automatic Elegance from a friend. The car run smooth. After 2 days I noticed thick white fumes from the tailpipes. I suspected excess engine oil, checked the dipstick, the oil was in excess of the max mark in the dipstick. I got all oil drained and about 8 litres of oil came out. I repoured that oil till the half of the dipstic (between max and min mark). Now I notice that white fumes are there but they have reduced. I also opened and and checked the MAF (mass air flow) sensor but that seemed to be clean and dry. I also noticed that white idleing there seems to be a engine missing in between. I undrstand that it has 12 spark plugs. I am a DIY freak and would like to know the following from the tech extperts here : 1. Why white fumes ? Is it due to excess engine oil / wrong grade engine oil ? Oil was very thin when I checked it. 2. Is it due to misfiring due to some faulty/shorted spark plugs. 3. If I want to change plugs - are they available with bosch or NGK etc at the local Bosch or local parts stores ? 4. What grade of oil to be used and how much oil does it take to replace ? 5. I want to drain all old oil from the engine and refill with fresh oil. How to drain the engine completely ? Is it possible through the drain plug or need a sucking machine ? 6. Do I need to use only synthetic oil or can I use Castrol Magnatech non sythetic oil and what grade and how much. 7. Is there a possibility that the head gasket is blown and thats why white fumes ???? 8. Is there a possibility that automatic transmission fluid is leaking on to the heads and burning in the engine ??? (very remote chance but still....) 9. The dash board engine management dispaly is not showing any fault codes except a blown parking lamp. I am here to ask these questions as I dont want to be at the mercy of the local Merc garages who will make hefy bills for nothing. I would be grateful if any experts here can answer my questions in the same sequence. I am based at Gurgaon. Before taking the car to a Merc mechanic I want to be sure of why i am going there ???? Any help would be highly appreciated. Thanks & Regards. Quote Share this post Link to post Share on other sites
fitsandy 0 Report post Posted March 28, 2011 I can be called at 0,97,16,86,89,73. Thanks. Quote Share this post Link to post Share on other sites
sarabjeet 3 Report post Posted March 28, 2011 looks like coolants finding its way into the cylinder. Check your radiator coolant level Quote Share this post Link to post Share on other sites
sgiitk 0 Report post Posted March 28, 2011 I ditto sarabjeet's diagnosis. At best you have a blown gasket, at the worst ... Quote Share this post Link to post Share on other sites
guiguiswiss 1 Report post Posted April 5, 2011 It's impossible to find the automatic gearbox fluid in the engine. For me too it's probably a head gasket problem.. What's your motor oil colour? No coolant in the oil?? In a V6 engine there are two head gaskets, it is not absolutely necessary to replace both. Quote Share this post Link to post Share on other sites
anjan_c2007 1 Report post Posted April 5, 2011 Again drain the engine oil and please check for coolant-water getting mixed there that may have added to the problem. If thats the case then a complete engine flush with appropriate solvents needs to be done. Better do this job in some good workshop. Quote Share this post Link to post Share on other sites
guiguiswiss 1 Report post Posted April 5, 2011 Yes but if the the head gasket leaks the problem will repeat Quote Share this post Link to post Share on other sites
