visanj
Solution for i10 bumpy ride
Hi
I'm having i10 sportz 2010 model with stock wheels and tyres. Though from the beginning I'm feeling all bumps and potholes, nowadays this is irritating as I got back pain.
Could anyone please let me know if there is any solution to get plush ride quality?
Thanks
Visanj
Thread moved: ACI-Support.
BornFree2011-03-29 09:28:15
- Have you tried wheel alignment and balancing ?
- Also get the tires and tubes checked at some professional workshop and check if there is any defect in tire or tube.
- check whether if the steel wires of tires have not come out.
- Also keep pressure as per i10's standard.
For your problem it seems that you are victim of defective tires.
May be you should also check the suspensions. May be the busing have worn out.
The only solution would be reduce tyre pressure by 2-3 psi for a better ride quality. Santro and i10 are known for their choppy ride especially in the rear. The trade off would be slightly increased fuel consumption.
I'm planning to sell my car and go for any other car with good ride quality
Could anyone please suggest me a car with good ride quality? Suspension/Ride quality is top most priority (Should be able to handle small patches to large potholes/bumps)
I have some options which includes Figo, Punto, Micra and also I heard new wagon r has good suspension. If wagon r is really good in terms of my requirements then I am willing to go for this as i don't need to spend much
Please suggest.
Thanks
Visanj
