ishanb1
tyre problem
I bought beat diesel on 12th August, 2011. The problem is two of the rims are getiing slightly tilted due to which car allignment is getting effected. Should I contact the chevy people, does it come under warrenty or should I just go to prviate company and get it rectified?
speak to co. first, ths is not a normal problem. and they will definitely solve it if you back it up with written e-mail marking senior guys along with sending letter for the same matter. and it does come under warranty if you normal user and not using your car very often for long trips
Firstly pls check the below -
1. Is the tilt quite visible?
2. Has there been any kind of impact on footpaths/pavements etc?
3. When you drive is there any pulling??
Once above things are verified it will be clear to solve the issue
Well you have paid for it and obviously you have the right to approach them and ask them to rectify it.
And as "mumbaiindians" said "they will definitely solve it if you back it up with written e-mail marking senior guys".
