problem in swift vdi
brijesh41183
hi,
I have a swift vdi and i have given the car for 7 servicing at MASS and the service was done. But SA Told that my swift has a problem of caliber pin,steering o/h, front suspension o/h and he told me that to solve the problem it would cost you around Rs 17000 but i don't think it would cost this much .can i do this work from outside mechanic but i don' t know anybody and can you provide me a good automobile worshop at navi mumbai who do this work and I can trust him please reply
Link to comment
how to identify the problem the steering overhaul
Excessive Free-play in the Steering wheel at both standing & while moving is the first indication.
EPS(Elec Power Steering) in Maruti Suzuki cars are almost maintenance free' date=' if the Wheel balancing & Wheel Alignment is checked & maintained properly.
Also, keep an eye on it, if you feel the Inconsistent Power Assist in it.
and front and rear suspension overhaul please reply
Excessive Diving & Suspension noises are the Primary Indications of Suspension maintenance.
P.S: For better life of both Suspension & Steering system, Do get both of these Inspected once after 20-30k kms.
Link to comment
the noise which is coming is caliber pin and i shown the car to a person who work in MASS previous jobs he told front suspension is good and steering is also good and he told me that your car does not required wheel alignment and balance because it is accurate and he also told me there nothing problem in your car but MASS has giving me a remark that steering o/h, front suspension o/h, caliber pin ,wheel alignment work should me done. So please tell me what should i do.
Link to comment
  • 2 weeks later...
  • 1 month later...
My swift vdi has completed 47302 km. I have not done suspension and steering overhaul but i have change the front stablizer and caliber pin work from reputed workshop. I think steering is little hard and i don't listen any tik tik sound from steering while turning or driving but yesterday while driving a car in traffic the steering has become hard but after some time it become normal what would happen to steering and what will be the problem in steering ? Please reply
Link to comment
  • 1 month later...
I bought a Maruti Swift VDI in Feb 2011 which has covered 3500 kms till date, in one year. In the first free service, Engine oil was changed and it cost just around Rs 750/-. However, in the third free service last month (10000 km/1year), engine oil was changed again (this time with some exotic castrol grade) and it cost around Rs 3400.00. The Maruti authorised dealer said Maruti has changed oil specifications!
My question is whether Maruti is overdoing the oil specification?
Please recommend a good engine oil brand/grade and frequency of change- considering my running is not much.
Link to comment
I bought a Maruti Swift VDI in Feb 2011 which has covered 3500 kms till date, in one year. In the first free service, Engine oil was changed and it cost just around Rs 750/-. However, in the third free service last month (10000km/1year), engine oil was changed again (this time with some exotic castrol grade) and it cost around Rs 3400.00. The Maruti authorised dealer said Maruti has changed oil specifications!
Link to comment
  • 2 months later...
hi
no maruti is not doing but dealer are doing. GO with company user manual specification. the engine oil i use is mobil delvac mx 15w40 in my car. it is good engine oil and most of using it or your running is low go for engine oil interval 10000 km/1 year which is earlier and i will tell stick with company user manual not more than that.
Link to comment
  • 4 months later...
hi friends,
I have swift vdi which is 4.5 year old and ran around 55120 km. I want to ask you a question about of swift vdi. In the morning i start the car and kept it 2 min idle to warm up engine than put tne reserve gear release the clutch than the car come back after that i put the first gear and than while releasing the clutch the car vibrated more and after that i put the second gear and than i release the clutch the vibration does not occur at that time if speed is low the vibration occur and after that in whole day when engine is hot or warm the vibration does not occur while releasing the clutch at any speed which is low or high. Please tell what should happen in a car or what is problem or is clutch is damaged. Please reply.
Link to comment
Archived
