AUTOYAAR
Are yellow fog lamps banned ?
Particularly I haven't heard about this latest law implementation but It doesn't matters much even they're banned as, the latest type of Foglamps are having a bit more Sophisticated & better design, as these are having Clear external lens & Internal bulb with dispersion glass, which splits the white light into many colours, which infact gives better visibility in fog than only yellow wavelength generating Traditional yellow lensed foglamps.
IIRC Yes, yellow lamps are banned(but not regular ones). If you want more out of your fog, you can simply go for higher wattage lights with proper relay and cutout. Fog lamps are focused and hence will not blind others.
