Apple1582
Chrome or wood inserts for Polo...
I have seen the chrome inserts on Vento Highline. Can i get the same for my Polo either from VW showroom or after market. I am much more interested in getting wood inserts but not sure whether i can get those in the after market - (have seen wood inserts for swift and innova)
Any information on the above is most welcomed.
By now, I haven't came across any Genuine Wooden trim accessory for New Polo or Vento.
However, you may get Chinese-faux wood/Rubber Glue strips for its Interiors at local accessory shop.
Silver inserts are a standard fitment on Polo & Vento Highline but I guess, these are not available in VW-Accessory section yet.
If you wish to buy them, then try to get it from International Online stores.
Try to contact Autografix. They are OEM supplier of some cars. Other such stuffs available at shops are cheap pasting which do not last long and fall off. Also they make permanent glue marks all over the dash.
Unless you get decent stuffs from good brand, drop this idea. I have seen people having silver painted dash components. If done by removing each dash panel, they look good and is much long lasting.
Thanks for the information.
I found wooden dash kits for Polo, but unfortunately its for left hand drive models. But some piece will fill on both left and right drive models - i guess. Link is here
http://www.carid.com/2012-volkswagen-polo-wood-grain-dash-kits/item-136923.html
Your take on that?
And is there any On line stores i can trust?
I have contacted the specialists in carid and they said will confirm whether i can fit the pcs in right hand drives and i requested them for real pics of dash kits for Polo. Seems genuine but not sure.
I found wooden dash kits for Polo' date=' but unfortunately its for left hand drive models. But some piece will fill on both left and right drive models - i guess. [/quote']
Yes, you can get some of the bits, like AC Switch shrouds, AC vent louvers, Steering wheel & Door trim inserts, etc.
