sham
FInally my '09 punto AUX'ed (Stock stereo itself)
Hi Guys,
I"m extremely happy to share this post and finally I managed to get AUX on my "Default stereo".
Here are some pics.
http://imagebin.org/198052
This shows the back panel and the new pin is the "Yellow Clip" that you see. (Its that easy)
http://imagebin.org/198053
Putting it back together.
This whole process was just a 5 min job and now I have AUX in my carsmiley32.gifsmiley32.gif
The place where i got it done is called "HiFi cars" in Jayanagar T-block area.(PM me for contact info and further address).
This man was extremely professional. I would urge you to go .
NOTE FOR PUNTO OWNERS..
If you're punto is a "2009" or before "June-2010" model then you can get this change done.
Apparently newer versions of the blaupunkt has a firmware change that does not facilitate this.
Secondly FIAT ships 2 brands of stereos,
1.) Blaupunkt
2.) Delphi
(This mod will not work if you have the latter).
How to check if your HU supports AUX?
Press the CD button "twice", if it changes to AUX then you have AUX support and only need to get an AUX-in otherwise bad luck.
