mahilaljayanath
Maruti 800 Starting problem
My Maruti 800, Carb 1996, engine overhauled two years back.
I can start the engine in the morning and in a traffic when the engine is hot.
But it is very difficult to start the engine after 10-15 minutes after few miles run.
But if I let the engine cool for 1 hours I can start the engine
It's called a vapor lock...in most cases and is caused by a problem in the fuel delivery.   It can also be caused by faulty ignition components so you have a lot to check.
I replaced my radiator two years ago. Water pump too seems to be working fine [AsI open the radiator cap when the engine is running (when warming up), I can see the coolant flowing (thermo valve not installed)].
I suspect there is a overheating issue. So what can be the culprit for overheating if the radiator and water pump are ok?
