fuzz123 0 Report post Posted June 17, 2012 my 2007 civic mt has been making this weird noise since the last two years. like that of an old spring that needs to be changed. i have given it to the workshop 15 times and all they do is lubricate it and return the car. it works fine for 5 - 7 days and then it returns again. they say the clutch is hydraulic so there is no spring involved. recently i got the entire clutch overhauled, with a new clutch plate, and 15 days later the noise is back. 3 different workshops have heard the noise and do not know what to do. any suggestions? Quote Share this post Link to post Share on other sites
sb-alto 21 Report post Posted June 17, 2012 Is it a pedal pressing noise or one that comes from the gear lever ? Or anywhere else ? For the first two situations, I believe it is a less grave issue and can be resolved with cable adjustments. You can try changing the gear oil. It worked for me, when a spring like noise came from below the stick. Quote Share this post Link to post Share on other sites
fuzz123 0 Report post Posted June 18, 2012 The noise comes from the pedal. Every time u press it And when u release it slowly. Jus changed the gear oil last time it was serviced Quote Share this post Link to post Share on other sites
banadictaustin 1 Report post Posted July 10, 2012 Personally i think its nothing to worry about, keep in mind if you want to replace it, you have to take of your gearbox and it`s like changing a clutch. I think you will find it makes that noise on acceleration and also on engine breaking , the civics are known for this problem with some of the box being weak hope this helps. Quote Share this post Link to post Share on other sites
