Sandy
Piaggio Fly125 will hit the market in Diwali
The Italian scooter maker is planning to bring the Fly 125 to Indian market. The scoot could be launched as soon as in Diwali season this year and should come with a price tag of about INR 50,000.
Fly 125, which is already doing duty in international markets, is a lightweight and compact scooter with a 10.5 bhp 124cc single cylinder 2-valve engine. The motor is mated to a CVT transmission and has good fuel efficiency.
The Fly is equipped with a set of telescopic hydraulic shock absorber upfront and twin hydraulic shock absorbers with preload adjuster at the rear. The scooter rides on 12 inch wheels with tubeless tyres. Anchoring duties are courtesy a 200 mm disc and 140mm drum brake for front and rear respectively.
The new Vespa has gained a lot of publicity and have grabbed a lot of eyeballs. However, owing to the high price tag, the sales performance of this lifestyle offering is nothing to write home about. All this is looks ready to change with the introduction of Fly 125, which will be an international offering at a realistic price point.
Technical Specifications
Engine Type
Single cylinder 2-valve Air-cooled 4-stroke
Cylinder Capacity
124 cc
Bore X stroke
57 x 48.6 mm
Max power at shaft
7.8 Kw (10.5 HP) at 8,000 rpm
Max torque
10 Nm at 7,000 rpm
Starting
Electric
Transmission
“Twist and Go” Automatic Transmission (CVT) with Automatic Clutch
Chassis
Steel Tube with reinforced plates
Front suspensions
32 mm telescopic hydraulic fork
Rear suspensions
Hydraulic single shock absorber, spring pre-load adjustable to 4 positions
Front brake
200 mm disk, floating calliper with twin pistons
Rear brake
140 mm drum
Front tyre/rear tyre
Tubeless 120/70-12”, Tubeless 120/70-10”
Length
1870 mm
Width
735 mm
Wheelbase
1330 mm
Seat height
785 mm
Dry weight
112 kg
Fuel tank capacity
7.2 litres
Max speed (km/hr)
94 km/h*
Emissions
Euro 3
Accessories
Windscreen, 33 liter top box, Chain lock
Colors
Blue Midnight, Black shine, Excalibur silver, Binaco Polare
(source:motoroids)
Engine Type
Cylinder Capacity
124 cc
Bore X stroke
57 x 48.6 mm
Max power at shaft
Max torque
10 Nm at 7,000 rpm
Starting
Electric
Transmission
Chassis
Front suspensions
Rear suspensions
Front brake
Rear brake
140 mm drum
Length
1870 mm
Width
735 mm
Wheelbase
1330 mm
Seat height
785 mm
Dry weight
112 kg
Fuel tank capacity
7.2 litres
Max speed (km/hr)
94 km/h*
Emissions
Euro 3
Accessories
Colors
(source:motoroids)
After looking at this thread, I googled about it & look What I Got!
http://www.uk.piaggio.com/media/06032012_piaggio_brochure_2012.pdf
Piaggio has a lot to offer!
Just Imagin what buzz will be created if this whole range is launched in India!
If I were CEO of Piaggio, I'ld launch tyfoon & Sport Touring & Concentrate on the scooter segment rather that 6-seater rikshaws!
This will bring company more profit & prestige!
This one should be priced on par with the competitors, else Vespa is in for a big dive southwards.
I think Italian auto maker Piaggio company have to rethink with the price of the scooter which will be launch on Diwali becasue price is one of the major reason.
