ACI Review: Chevrolet Sail Sedan
PrancingHorse
Chevrolet may not have achieved much success with its original mid-size saloon for India, the Aveo, but it could have just the product to change things. The car in question is the all-new Sail, the saloon version of the Sail U-VA hatchback launched some months ago. We drove the car near General Motors’ plant in Talegaon near Pune and came away quite impressed.
As can be seen, the Sail looks identical to its hatchback sibling right up to the B pillar. That means the styling is conservative, though the combination of its split grille, upswept headlamps and rising beltline look pretty neat. But while the Sail U-VA isn’t too attractive from the rear, the Sail saloon manages to look quite smart, with the nicely arced roof flowing smoothly into the neatly integrated boot section. The Sail is a proper saloon in that respect, and doesn’t have the truncated look of the sub-four-metre Maruti Swift Dzire, which will be among its chief competitors. The rear wheels, however, look a tad too small, and the rear overhang is a bit too pronounced. Styling at the rear is neat and simple, with the large triangular tail-lamps helping to distinguish it from the other mid-sizers.
Boot space is pretty impressive, and what helps further is that the loading bay is well shaped and can easily accommodate two large suitcases. Sadly, the loading lip is a tad too high, the sill is slightly narrow and the rear seats don’t flip forward like they do in the hatch.
Access to the Sail’s cabin is really convenient thanks to the wide-opening doors, but once inside, there’s some disappointment. The interiors are unchanged from the U-VA, so what you get is a cabin that lacks the premium look or feel of some other cars in this class. Plastic quality is only decent and the beige tones in the cabin make the Sail look a bit dull on the inside. The dashboard doesn’t look like anything out of the ordinary, although the protruding centre console is smart in its own right. What takes some getting used to are the power window switches, which are awkwardly positioned in front of the gear lever, and the small digital tachometer. The lift-type door locks are a bit old-school too, and you’re also likely to rue the absence of steering-mounted audio controls even on the top LT spec cars. Top variant Sails do get an audio system with Bluetooth audio streaming and telephony, however.
Front seat comfort on the whole is good (though there’s no driver seat height adjustment or dead pedal), and visibility is nice too. Rear seat occupants will like the space on offer. There’s good knee room and headroom is also sufficient for anyone under six feet tall. What’s nice is that Chevrolet has softened the seat back cushion (a complaint on the Sail U-VA) and this has greatly enhanced comfort. As with the U-VA, the Sail comes with its fuel tank under the front seats, and this creates a natural footrest for the rear passengers – whether or not you like it is a matter of taste. This layout has also freed up some storage space under the rear seat, enough for a couple of soft bags. All in all, the Sail scores quite well in terms of space for smaller items, with a total of six bottle-holders (including two in the rear centre armrest) and a large recess just ahead of the gear lever.
Like the hatchback version, the Sail is available with a 1.2-litre petrol or a 1.3-litre diesel engine. We drove the 85bhp, 1.2 Smartech-equipped Sail first and liked the engine for its top-range pep. It’s a motor that’s quite comfortable at part throttle, but is unquestionably at its best in the 4000-6000rpm band. However, the engine is quite noisy and the sound gets quite intrusive above 3000rpm. What also takes away from the experience is the snappy, long-travel clutch. The five-speed gearbox on the petrol is also not that precise and is rubbery to use.
The Sail diesel proved to be more impressive. The engine is the same 1.3 Multijet used on a wide array of cars in India, and in the Sail comes with a fixed-geometry turbo to produce 77bhp. Chevrolet’s engineers have done a great job to smoothen this engine’s power delivery. There’s decent power off boost, and even when the turbo comes in at around 2000rpm, the power doesn’t come in sharply like in a Dzire. The build of power is gradual and helps make the Sail easy to drive in city conditions. The smooth-shifting gearbox and fairly well-weighted clutch only help matters. Mid-range performance is good too, though the Sail doesn’t seem to have quite as much top-end grunt as the Dzire.
We liked the Sail’s steering for the minimal effort it required at parking speeds, but were quite disappointed by how disconnected it felt when we ventured onto the highway. Surprisingly, straight-line stability is also not all that good, and calls for a firm hand on the wheel at all times. The petrol car’s steering does offer a little more by way of feedback, but even then it’s not really entertaining to drive. There’s plenty of roll around corners too. But if not for handling, you’ll definitely like the Sail for its ride quality. The suspension easily absorbs the worst of our potholes, while the 175/70 R14 tyres do a nice job of smoothening out smaller imperfections. It really is one of the best riding saloons around.
On the whole, the Sail come across as a pretty interesting product. It looks smart, has a spacious cabin and a useable boot, and really impressive ride quality. In diesel avatar, the Sail seems well suited to city use and promises to deliver on the fuel economy front too, with an ARAI-test figure of 22.1kpl. The petrol Sail is not bad on this front either, with a claimed fuel economy of 18.2kpl. Were the petrol motor more refined and the cabin better finished, the Sail would have been an excellent all rounder. The problem is the Sail is up against some very stiff competition from the Maruti Swift Dzire, Mahindra Verito, Toyota Etios and Tata Manza. But if Chevrolet can price the Sail between Rs 6 lakh for the base petrol model and Rs 7.5 lakh for the top-end diesel, it could just have itself its first big mid-size saloon success.
Link to comment
Side profile looks Vento-ish.. Overall the car's design is good. But it will surely fail in fit and finish and the quality of materials used.
The earlier Aveo was definitely leaps ahead in terms of quality. Don't know why suddenly this has turned around with Chevy.
Link to comment
@neerajd: I agree. The Aveo has really good quality interiors and going by the review the Sail fails in that department. Still credit to GM for making it look like a proper sedan and not a boot cut paste job. I actually like the ear 3/4 view. Lets see how it does. I have seen any Sail UVAs on the road since its launch
Link to comment
Exactly, the exteriors looks very nice, but it's the worst interior ever seen! :( & this quality is not even acceptable at M800 money! the gap lines between body panels are so broad, that they are clearly visible! & this all things will lead to another disaster!
Link to comment
  • 2 months later...
People seem to be taking on the Sail in a big way 7000+ bookings and so many of them that i see on the road, i had never anticipated this level of success.
People did not find the Chinese link to bother them.I guess any CHEAP offering with proper dimesions of a sedan will find takers.
Link to comment
Chinese are doing their best to ensure quality, except the Sail's interior, rest is quite acceptable, remember the test mule of Haval H6 and Tunland pickup has been spotted in India which suggests India is getting ready for Chinese onslaught of cars.
Link to comment
Those will remain just booking and not sales. I have never seen a Sail in Chennai, got to see 2 sail. With Amaze being priced so close to Sail, who on his right sense would buy this.
Link to comment
@creativebala
Thank God for that , i was myself shocked with so many intented buyers for the Sail, i had in my earlier post expressed my dismay about it doing so well inots bookings.
The Amaze pricing gives a second chance to those who have commited a sin earlier by booking a Sail, hoping sense prevails all along.
Link to comment
Archived
