saurabh.khatri17@gmail.com
can power steering and window fitted in maruti zen 2006 model
MGA Power windows(set of front 2) costs ~5k for Zen/Alto/Wagon R.
But it's not possible to fit Power steering, as it's a very costly & complicated affair for an Old car & in any case if possible it'll cost massive for such a change.
Retro-fitting Power Windows is a normal/regular job, no issues what-so-ever. PS becomes a tricky affair, it can be done & many people used to do this in 90's when not all variants came with PS. But suggestion is to avoid such a job. If you still decide to go ahead, go through the Authorised Service station.
A friend of mine had got power steering fitted to his Qualis It was a fantastic job and worked flawlessly but not everyone can do this. You can check if a conversion can be done if you could source a Zen power steering unit from somewhere but I would still not recommend it. Power windows is an easy retro fit
can power steering and window fitted in maruti zen 2006 lxi model?
I want an advice?
I think either you have mentioned the wrong variant "Lxi" or your car comes with EPS (electronic power steering) already.
MSIL gives "i" to all its models with power steering.
Please check once.
Edited by Sstar
