Richie Rich
Honda Amaze versus Swift Dzire
The new Honda Amaze takes on Maruti Suzuki Dzire in the latest battle budding within the automobile industry. Priced nearly alike and from the same segment, choosing between Amaze and Dzire is a smart consumer’s nightmare.
To begin with, Amaze contains a 1498cc engine in its diesel variant, while Dzire comprises of a 1248cc engine. Dzire provides a mileage of 23.4kmpl, whereas, Amaze dominates the segment with a mileage of 25.8kmpl. Diesel version of Amaze consists of an i-DTEC engine, which generates more power than the Dzire compatriot. So, if power is what you look for in a car, choose Honda Amaze.
Now, for those who consider looks to be a make or break deal. Being a fan of the older version of Dzire, I believe that Maruti Suzuki could have done better with the redesigning. Please note that I do not have any problems with the front looks of Dzire, it is the back where the problem lies. Back of the Dzire is way too flat for a sedan. Amaze, on the other hand, looks stunning up ahead and decent at the back. When you stand beside it, you can also admire the ‘sedan’ in the car.
Having spoken about the exteriors, we now step inside the car. Interiors for Dzire can be summed up in two words, ‘simple and classy’. Maruti Suzuki are spot on with the interiors. They look good, enable easy functioning, clear and direct. Amaze loses the interior fight because of its cluttered presentation on the inside. It often looks like some buttons and air conditioning vents put together in random fashion just because the deadline was nearby and the interiors had not been designed yet.
Now, we will discuss about the space. Amaze again comes out on top in terms of in-car space. Better leg room, more boot-space and sufficient breathing space, Amaze provides comfort over long drives for all its occupants, be it on the front seat or the back. Dzire, on the other hand, provides good leg space for the people in front, but could use some more for the people in the back. Boot-space has been compromised from the previous version of Dzire
That is all about the cars, now, in a brief we will discuss about their manufacturers. While Maruti Suzuki is an established brand and is one of the big guns in India, Honda is not far behind. Honda, with its effective after sale service, has climbed the ladder as India’s most trusted brands and continues to rise. Sure, it’s a bit more expensive than Maruti Suzuki, but it is in a different league, a better league.
With all that we have discussed here, Amaze seems to be the obvious choice, unless you are a big fan of pretty interiors.
what abt low ground clearance at 165mm which might scrape speedbreakers
Anirudh, 165mm is sufficient ground clearance for Amaze-sized car. Scraping the breakers also depends upon on the speed of the car at which it approaches the breakers. Moreover, Dzire has a clearance of 170mm, which is almost exactly the same as Amaze, so, rest assured, if a breaker scrapes Amaze, it will surely scrape Dzire as well.
