chirag219
Speakers for Skoda Yeti...
I have a skoda yeti and have the factory fitted touchscreen bolero system with 4 components (4 speakers + 4 tweeters) ... i m quite satisfied with the touchscreen head unit which has an aux port.. also the front components are impressive.. but the 2 rear components are inferior and not at all matches the quality of front components.. so can anyone suggest me better components which may replace the already fitted speakers which are compatible with the speaker?? Also is it possible to install a subwoofer with the amplifier on the current bolero head unit???
If you are looking for good quality output from rear speakers, it may not be possible to achieve this by just changing the speakers.
Good speakers are also power hungry .. So your stock head unit may not be able to supply sufficient power to the speaker and in the process it may also damage the head unit and speaker itself.
The best option would be to go in for a 4 Channel AMP and power the new rear speakers via the AMP and you can use the other two channels for the sub woofer.
